Old 04-02-2017, 02:10 PM
Masmith Masmith is offline
Default 1450 and tiller
Bought this 1450 and tiller for $350. I just wanted the tiller set up but he wanted $275 for the tiller and $75 more for all of it. Spent 20 minutes cleaning out the mice nest and wasp nest. My 16 year old was certain it would start. I was very skeptical. I was just hoping it wasn't locked up. Poured in some gas Tank was bone dry. Hooked up a charger and the lights worked and it cranked over. To my amazment it started up and sounds great. No smoke. Idles and revs up.
Old 04-02-2017, 02:59 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Looks like you have a tiller in time for spring!!
1- 1200 in pieces
1- 1864 in pieces
Old 04-02-2017, 03:22 PM
Default Three point set up
While taking off the tiller and seat to clean everything and check fluid levels I noticed it was held in place by large bolts and not the solid rod with cotter pins on each end. This is the first quiet line model I've owned. Is this normal?
Old 04-02-2017, 03:25 PM
The later ql tractors had the bolts.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-02-2017, 04:00 PM
You got better than a Lew deal.
Old 04-02-2017, 04:03 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It is beat...but I like it! Great buy!
Queen Of The Quietlines!
Old 04-02-2017, 04:53 PM
You got a nice deal!
Old 04-02-2017, 08:06 PM
Yes, that is correct. Yours uses the "frankenstein" bolts and has a 7/8" hole where it mounts.
If it used the pin, then the hole would be 5/8"
Old 04-02-2017, 08:09 PM
Looks like it will get the job done.
Do you have a garden?
Up to 534 and counting...
Old 04-02-2017, 08:45 PM
dodge trucker dodge trucker is offline
you suck.....
