I was finished with all my prevented maintenance on my cub , So I went to reinstalled my Haban mower deck. When I raised the mower deck up after I hooked up all my clips and brackets , the front of the deck raises much higher than the rear . I'm new so I really didn't pay a lot of attention to the mower deck before I took it off can anybody tell me if this normal or do I have something hooked up wrong . I looked at all the places where it attaches to the tractor and it looks okay . I'm hoping for some word of wisdom from all the cub guru out there !
This is how I had my Haban hooked up. I wouldn't worry too much about it in the raised position as long as it is running on the wheels when it's running.
I have used my 2072 with the 60" Haban for Probably 5 years now. I would have to say it lifts pretty level front to back.....But it only lifts a total of about 2" maybe 3". It doesn't lift as much as some of the other garden tractors. I now have my supported by chains at four points as the weight of that deck was really wearing the hanging hardware. I know guys say to let u it ride on the casters....That will b for another time. Definitely don't step on the deck while lifted. U could while it's resting on the wheels....But even then I try not to. Some close up pics of the lift points would help diagnosing your situation.
No No , it goes all the way down so the casters are on the floor , when you look at it the rear is setting lower than the front when you raise it up . I looked at the picture it seems to be the same and in the back there is a little hook flat bar that is hooked into the tractor, that looks the same is there any adjustments as how far it's suppose to go down ?
Here is the link to the PDF for the Haban 374 manual
http://www.mtdproducts.com/equipment...ter+Serial+%23 Follow the set up directions carefully. Make sure your mule drive/ hanger/mounting brackets are assembled correctly.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Thanks for the haban manual , I going to print this and make sure that everything is attached correctly . Thanks again
Okay so I had senior moment , I went through all the pictures and made sure that everything was attached to the tractor like in the pictures of the manual , I check to see when I lift up would it move up or down like if something was stuck , no everything was good . So I raised the deck up and with the hydraulics and thought lets measure the deck to the floor . To my surprise the damn thing is level it must be an optical illusion. the back of the deck is within a 1/4 of inch to the front , but when you look at it looks lower in the back then the front . Thanks and sorry it was my mistake sorry for taking up your time I feel pretty silly right now.
[QUOTE=Thanks and sorry it was my mistake sorry for taking up your time I feel pretty silly right now.
![]() Don't worry it's all good in the den. |
Well...your not completely wrong. The front of the deck is thicker with what we will call the "discharge tunnel". I could see how u were second guessing.
....and lets just say....we have all made mountains out of a mole hill at some point Glad u got it all squared away! ![]() |
