Old 04-15-2017, 02:01 AM
shumway072 shumway072 is offline
Default 2086 PTO issue
Hi all,
New to the forum and have just picked up a 2086 with a 60inch deck. run great and no leaks but when i engage the pto, it kills the motor instantly. is this a sign of the pto locked up of is there an adjustment on the pto?
Thanks, Steven
IH
1000
1250
1450
1650 with 1 A tiller
682, 782 (Feb 81) 1282
1863, 2086
Steven
Old 04-15-2017, 07:07 AM
First, welcome to OCC....
What do you mean "kill's the engine..??
(A) Does that mean, that when the PTO it appears that something is dragging down the engine and it stalls out...??
(B) Does that mean, like someone flipped an electrical switch and it dies like turning the lights off...??
Old 04-15-2017, 07:53 AM
dale c. dale c. is offline
does the mower turn free by hand ? were you sitting on the seat ? if not then the safety switch on the seat would shut it down . if it's still hooked up ?
Old 04-15-2017, 12:18 PM
EricR's Avatar
EricR EricR is offline
Welcome shumway072, I have a 2086 also and can tell you this, let the tractor warm up and have the throttle at least half to 3/4 full. Sorry just the nature of the beast...
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 04-15-2017, 04:54 PM
Same deal with the Kubota engines both diesel and gas, they just don't seem to have enough low speed grunt to handle the Haban 60" mowers. The Kohler CH's seem to have more low speed grunt. Just my 2 cents.
Old 04-16-2017, 11:04 AM
EricR's Avatar
Sam, I have a 54 inch deck on the 2068 but I do have a Haban that I have never tried but (what I think) is the different clutch is the key here...
Old 04-19-2017, 01:37 AM
Default pto issue
Thanks to all for sharing thoughts on the pto issue. First to be clear, the 2 times i tried to engage it it stopped the motor completely.( kind of like when you run a push mower over a stump!) Second i didnt have it fully throttled up so maybe that had something to do with it. i have taken the deck off and all pulleys are free and can be turned by hand on the main pulley. i did engage the pto with deck off and all seemed fine. perhaps i will put it back on and let it warm up and full throttle to see. thanks again for suggestions
IH
1000
1250
1450
1863, 2086
Steven
