Old 04-15-2017, 07:37 AM
Dirty Steve's Avatar
Default Finally, the lawn is rolled!
I was out till after 9 PM the other night and finished with help last evening. Local guy makes those rollers out of old propane tanks. Around 1000 lbs if fully loaded with water. I leave it down about 8 inches. It's tough on my Wheeler. Have not dared to try it behind one of the SGT's. I bet a Kubota would handle the roller real nice... I'll tell the wife. Alls I'll get is
Old 04-15-2017, 08:25 AM
Cute pic. Now that is what I call a roller.
Old 04-15-2017, 09:14 AM
john hall's Avatar
Cool roller. Now educate us Southerners why you roll your yard. Frost heave or something? I got a roller that is about 20-30 gallons--it has a handle so you can hand roll it. I did used it after they put a new roof on the house to mash down any nails that got missed--I went over the yard 3x's with a BIG rolling magnet first. FWIW I used a couple clevis so I could hook the roller behind dad's 100.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-15-2017, 01:23 PM
Steve, of that 4 wheeler will pull it, you don't need a SGT. Your cubs will jerk that roller around with ease. Actually that's hard on the slip clutch in your 4 wheeler..... they aren't tractors.
John,
Yes, frost heave leaves the ground very rough. Plus, bugs, moles and the like do too. Very narrow window of opportunity to roll when it is most effective. Ground is softest in the spring, shortly after the thaw, but after it has dried once. The window here is long gone. Not to say you can't use a roller later, but it isn't as effective.
Old 04-15-2017, 02:12 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I agree that the Cubs would do a better job pulling the roller and be easier to maneuver. I'm pretty sure that Polaris uses a CVT and most of the abuse would be on the belt. I don't pull anything heavier than the log splitter with mine.
https://youtu.be/uCEvBGT8twM
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-15-2017, 04:45 PM
Your right. I didn't pay any attention to what brand it was.
Old 04-15-2017, 05:36 PM
twoton twoton is offline
Awesome roller Steve.
Old 04-15-2017, 08:22 PM
DieselDoctor's Avatar
Steve - what's the local guy get for one? I've always wanted to make one, but have never gotten around to doing it. Probably should just buy one and be done with it.
Old 04-16-2017, 12:44 AM
The wheeler pulls the roller well, just all the independent rear suspension makes it tough in the turns. Plus it is light in the arse end. I have the SGT rear brackets on the 2182. I need to weight it up and see how it pulls it. E-mail sent, Doc.
Old 04-16-2017, 12:51 AM
Cool roller, Steve!
