Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 04-18-2017, 09:55 PM
Shotgun Clay Shotgun Clay is offline
Thumbs up Some garden work
I decided that I needed to "till" my garden because it was a decent afternoon. After turning the soil I used a bed boxspring to smooth it out. I will be planting tomatoes, peaches and cream sweet corn, white pumpkins, and yukon gold potatoes in it.
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 04-18-2017, 10:33 PM
john hall's Avatar
Ok that's some pretty heavy turf. You get someone to harrow/plow/chisel that for you with a farm tractor?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-19-2017, 09:47 AM
Great idea on the bed spring, sounds better then the pallet with cinder blocks on it I tend to use. We are attempting to get our Yukons in this week if it will dry out enough to work up the spud garden.
Ken
Old 04-20-2017, 08:29 AM
Default Ground
The spot used to be a farm field two years ago, the previous home owners let the person who farms the field near us use the space. I do have a plow, but still need to make a mount, I dont know what brand it is.
Clay
Old 04-20-2017, 09:07 AM
Looks like you just scratched the surface then wollowed it around with the springs. Better wait to plant anything until you get a real plow and really work it.
Old 04-27-2017, 11:03 PM
Default Update
Got my plow hooked up and plowed the garden. It was my first time using a plow, it was interesting The part where the plow hooked to the hitch kept failing, so I upgraded the 2 bolts attaching the adapter block to the hitch. After plowing I took a cultivator to break up clumps and smooth some, then used the bed boxspring for extra smoothness. I will plant seeds once this cold and rain passes monday.
Clay
Old 04-28-2017, 12:00 AM
sgt.porter's Avatar
sgt.porter sgt.porter is offline
Not bad for your first go round.
It's been awhile for me, but I like to work the ground several times before planting. It helps the sun scorch the grass roots, kills off more weed seeds, and gives the birds and rodents an easier go at picking out the grubs.
J-Mech is right, you want to really work it before planting anything otherwise your weeds will get out of control and your plants will grow slower in the packed soil.
Father in-law came and plowed 2 plots for me in Feb. I got my tractor running and tilled them up about 3 weeks ago, waited 2 weeks then spread a layer of manure and bedding from our rabbits and tilled it again with 2 passes.
Played in it a little bit today setting up my cultivator, but will start planting next week.
It's been 4 years since I was last able to garden. I don't expect my dirt to be truly conditioned this year, but I'm working it enough that it will be an acceptable (re)start.
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck
1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them.
