Old 04-20-2017, 09:52 AM
dbuck dbuck is offline
Smile 2185
I am thinking of buying a 2185. The only thing holding me back, is the number of hrs 1090. I have worked on several IHC 100 series tractors and have no knowledge/experience on this model. I would appreciate if someone could fill me in on the good and bad about this model. Is this shaft driven, both tranny/deck, or belt driven? Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 04-20-2017, 11:09 AM
Leadslingingdaddy's Avatar
Should be a Kohler Command... Great motors if taken care of.... Grass in the cooling fins and flywheel area are engine killers... Shaft drive, manual steering and lift.... Great re-power buys for older Cubs and Deeres..
Old 04-20-2017, 11:56 AM
pballard pballard is offline
Default 2185
what he said. one of the best donors around and usually very reasonable. I think they are more of a lawn tractor than the heavier duty garden type.
hope you have good luck- if taken care of it should prove to be good.
Old 04-20-2017, 02:38 PM
Smile
Thanks for the relies. Well the guy would not come down on the price 600$. An I be darn if I was going to pay that much for a tractor that old and 1090 hrs. So now I am looking at a 1650.
Old 04-25-2017, 09:28 AM
Smile
Well the 1650 did not work out. So I purchased an 1864, with a 54'' deck. The deck is a little noisy, but the seller threw in all the bearing and seals. So I guess in the next few days, I will get the deck off and go to work on the noise problem.
Old 04-25-2017, 09:57 AM
The 2185 (depending on the generation) rolled out of the Factory with a Kohler CH18-62509 or CH18-62588.
Old 04-25-2017, 10:26 AM
mickb72 mickb72 is offline
That's the best outcome of all three! Buy a lotto ticket.Cheers. Mike
Old 04-25-2017, 01:45 PM
CubDieselFan's Avatar
1864's are the best of the best. When installing the seals, the one at the bottom of the spindle needs to be upside down.
