Hey guys, I am in the middle of, or I should say closer to the end of this 682 engine swap. Went from the KT 17 to the CH20 (thanks to Olds, who did an outstanding job at crating and sending this motor)
You can buy the spacers for an 1864 part # 950-3009 Price $6.59 ea.
Thanks Sam, I'm sure I can buy those. But the question is, are they for proper driveshaft alignment? Like I was saying, without any spacers its already a hair too high, but not too bad. With any spacer at all, the drive shaft angle just gets higher (higher in the front). Is it ok to leave out the spacers? Thanks, TB
I don't have the answer to your question. All I can say is that the shaft on my 1864 looks pretty well aligned with the spacers.
Both tractors use the same height for the spacer. 0.469in. The newer ones are 1in diameter the old ones are 5/8in.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
I would use spacers. I made my own out of 3/8 cause I thought the .4xx ones
were a little high. I took a KT out and put in a Ch20 in a 782.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Thanks Terry. Yes the original spacers are too high for my liking as well. The fact that the 682 did not come with a CH series makes the dimensions different. The crank center is taller with the CH20 as it it was with the KT17. With the 3/8 spacers, was your shaft straight? Mine is still a little high even with no spacers. I'm trying to ask if NO spacers will hurt the motor. Thanks, TB
No problem if you mount it without spacers.
I would think setting the 2 engines crank to crank or measuring crankshaft
center line to mounting surface and comparing, would answer the question if spacers are needed and how much, or none @ all. Or would that be too easy? ![]() |
Hi TB, Stand back from the side of your tractor and look. With a level frame and spacers under motor you should notice the motor tips back.( high in front,low in back)May help driveshaft alignment. I think the spacers are for air flow. I've done this project a couple times myself. Mike
