My 2284 has the front pto mule drive with the 60 inch mower. I would like to use a small brush hog but it doesn't seem like everything I have read so far will work. I was going to buy the cat 0 3 point setup but then I have no way to power the brush hog. I haven't found any brush hog setups that can use a hydrostatic motor to power the mower. Any suggestions or am I just wanting too much from this cub. Thank you.
You can't use a rear mounted Bush Hog style mower unless it is made for that model tractor. Cub Cadet did make one, but you would have to have the 3pt hitch AND rear PTO installed on your tractor. The rear PTO and 3pt together will likely run you around $900 IF you can find one... and the mower will usually run in the $1500+ range.... IF you can find one.
Your better off finding a small tractor for use with a rear bush hog mower. |
J is correct. You could use something like this.
https://www.mowersdirect.com/lawn/to...ut-mowers.html
Thank you J and Oak. The swisher unit is what I started looking at last night. I have 4 acres of woods and brush to start cleaning up. Once I get stuff cleared I can put the 60" deck back on and mow. Putting a 30 by 50 shop in.
