Old 04-23-2017, 11:09 AM
Joelk Joelk is offline
Default Cub Cadet 3000 Series, substitute PTO Solenoid/Valve?
I have several 3000 Series Tractors and one of them recently had the PTO Vacuum Solenoid go bad,
I swapped one from another tractor to confirm that the valve was bad.
New from CC they cost about $80 and I will probably need more than one as I plan to keep using 3000 Series for a long time.
I am hoping to find a substitute that is less expensive. I did a bunch of searching on Amazon/Ebay and found many that look like they will work, with some fabrication.
I bought one and it should work, but I will need to make modifications to the wiring to use it.
The CC OEM valve appears to have a GM style Weatherpack Connector.
Has anyone found an inexpensive valve that will work with very little, or no modification?
If so, please provide link/photos/part#s
Thanks, Joel
Old 04-23-2017, 11:44 AM
Joel, I had one that wasn't working on a GT3100. I carefully took it apart and cleaned it. It worked fine after that. The little plunger in the last pic was sticking causing it not to pass the vacuum to the actuator.
Old 04-24-2017, 11:26 AM
Oak, Thanks for the info/photos.
I had considered trying to repair the OEM Valve, and pulled off the bottom cover, etc, but did not see a way to further disassemble without damaging the tabs that hold the "top cap" on.
Were you able to disassemble yours without damage? If so, how? If not, how are you holding it together?
Did you use any lube on reassembly? If so, what?
Old 04-24-2017, 01:45 PM
I just used the little screwdriver as shown in the pic, opened it up, cleaned it and snapped it back together.
