Old 04-26-2017, 07:25 AM
pballard pballard is offline
Default Deck question
I have a question regarding decks- I was recently given a 48 in cc deck listed as "48 GT Deck serial 317190", I think it came off of a Cyclops tractor- it will not match up with what is currently under the 882 but the question if I can find the correct mule drive will it the 882?? I sort of like this deck as it looks like it will float on the terrain opposed the original one.
I am also interested in others opinion of this deck.
thanks in advance- pete
Old 04-26-2017, 10:12 AM
It's not a question of mule drive, as it is a matter of subframe. You need a different subframe for it to work. Plus, the PTO on a cyclops had a larger pulley. You will need to change the drive pulley, or the PTO, but IIRC, you can swap pulleys with either an old "C" deck, or get one for an early cyclops deck that was for the tractor with the 4.5" PTO. Maybe Sam will come along and verify this as I don't want to go on a part number hunt right now. Feel free to peruse the parts books to find the answer yourself.
Old 04-26-2017, 12:40 PM
The OP will definitely need to match pullies.
I have several 48"/54" decks and IMO are the best decks CC made for the older garden tractors.
Old 04-26-2017, 03:11 PM
Thanks guys for the info!
Old 04-26-2017, 05:53 PM
I forgot to add, the spindle bearings are all replaceable with common bearings.
