Been a long time since I was last here but I have a question for you spread frame guys. I recently bought a IH/CCC 682. The problem I am having is the kt17II is blowing oil into the air cleaner. I took it off in the pics and ran it to see how bad it was, and covered the engine bay in oil. Is there any reason(s) it is doing this and where do I need to check first? Obviously the air cleaner is junk and I am suspecting a blockage at the ccv, but does it go deeper than that? I apologise for the sideways pics. I have a new phone and haven't figured it all out yet. Thanks in advance for your help.
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
A couple of things can cause it.
A worn out engine like piston rings. Also on the base of the crankcase vent tube is a valve cover. In it is either a rubber valve the size of a dime that could be bad, or there is a "reed" style flapper valve ( older design) and they tend to break off/malfuncton. this allows crankcase pressure to blow up to the aircleaner. Note: a small amount of oil in the air cleaner is normal, but not slobbering wet dripping kind of thing. investigate the vent valve first. Please download the free service manual available in our tech section if you have not already. ![]() Oh and read the manual |
My 2072 was doing the same thing, replaced the reed/umbrella/check valve thing George mentioned, problem solved.
George, I thought the reed was the new style? Anyway you have to buy the little plate assembly or something like that if it hasn't been updated because Kohler doesn't support the old design----going by memory here but I think that was the story when I worked on mine a few years back.
