Old 04-28-2017, 01:15 PM
Userj8670's Avatar
Default Strange sound when cranking 169- video attached
Not sure what this sound is when cranking but it doesn't sound good. Doesn't happen all the time.
https://youtu.be/t5m408PsoK8
Old 04-28-2017, 01:45 PM
Not sure what you're hearing Jim? If anything I heard some belt slippage I think during one of the cranks but other than that seems normal? Check belt tightness on starter generator
Old 04-28-2017, 02:02 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Maybe a humming voltage regulator or the hydrastatic transmission?
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 04-28-2017, 02:22 PM
That's what it sounds like to me.....
Old 04-28-2017, 02:24 PM
Terry C's Avatar
Terry C Terry C is offline
I think Alvy has the best guess. I couldn't really tell what that noise was.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-28-2017, 02:28 PM
Userj8670's Avatar
Thanks guys. To me it sounded like it was coming from the hydro. Depending how much of video you watched, it seemed the sound amplified when the tractor was set in motion.
I got some carb work to do as well on a side note. Won't run past idle for more than a few seconds without shutting off with a loud backfire
Old 04-28-2017, 02:32 PM
Userj8670's Avatar
OK just went back and rewatched. The noise I refer sounds like a squeel and can be hear @ 0:02 - 0:03. Additionally , @ 1:11 when I try and throttle up, the tractor cuts out (dies) and that noise is evident when it stalls? Would a belt be slipping when stalling?
Old 04-28-2017, 03:10 PM
That growling sound makes me think the hydro isn't all the way in neutral. Mine make that noise when I shut them down and the hydro isn't fully in neutral. Check all your linkages and make sure they are where they should be.
I hear the squeal too. Might be associated with the hydro not being in neutral. Might be worth a fluid/filter change in the rear end too.
Old 04-28-2017, 03:32 PM
mickb72 mickb72 is offline
Make sure your condenser has a good ground to a clean spot. Mike
Old 04-28-2017, 07:21 PM
cadzag72 cadzag72 is offline
That groaning noise is when the hydro has a load against it at low engine speed. Common if neutral is not aligned right, as others have said. Rough running and backfiring also can mean a bad or poorly grounded condenser. Good luck with it, you'll get it up and running in no time!
Ian
