Old 04-29-2017, 03:05 PM
Richs72 Richs72 is offline
Default Model 72 front power takeoff clutch bearing
How do I get the bearing off? I took out the set screw on the collar and pulled on it with a bearing puller and it won't move.
Old 04-29-2017, 03:10 PM
mortten mortten is offline
It is a locking collar. It holds the bearing with an eccentric. Tap the collar clockwise with a punch.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 04-29-2017, 03:19 PM
Thanks but one detail please - clockwise as I face the front of the tractor?
Old 04-29-2017, 04:04 PM
How about this. Standing looking at the front of the tractor, turn it opposite direction of shaft rotation when running.
Old 04-29-2017, 04:06 PM
Dart1917 Dart1917 is offline
Clockwise as you are looking at it- that is if the last guy installed it correctly.
Old 04-29-2017, 04:07 PM
The end objective is to replace the oil seal that literally fell out. Rather than just put it back I want to replace it. The part number I have is KH-X-583 which I can not find. Is there a replacement number?
Old 04-29-2017, 05:06 PM
I got the old seal out and now know the part number. Thank you all for your help.
