Old 05-05-2017, 08:39 PM
DieselDoctor's Avatar
Default Cat 0 Box blade
Perhaps some of you have seen the new product line of category 0 implements being sold on E-Bay under the name Impact Implements. I recently purchased a box blade and thought I would share with everyone some pictures.
http://www.ebay.com/itm/Impact-Imple...JY~aQv&vxp=mtr
The box blade arrived unassembled, but it is simple to put together. One nice feature is it has a replaceable cutting edge. The six scarifiers are height adjustable and can be positioned so that it can be used as a blade alone.
There was only one flaw that I had issue with, that being the the Cat 0 pins do not have a hex base so that they can be held in place while tightening them. I just used a taper punch to hold it.
Overall, the box blade is rugged and well built. It is of heavy welded steel and powder coated.
I'll post some more pictures when I grade my severely neglected gravel driveway.
Old 05-05-2017, 10:31 PM
Dirty Steve's Avatar
Looks beefy Doc. How is that 1882 running?
Old 05-06-2017, 12:00 AM
Terry C's Avatar
Terry C Terry C is offline
I like it!!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-06-2017, 12:04 AM
I haven't heard of them yet. I'm gonna go check that out!!
Looks good Doc! I wanna hear how well it works.....
Old 05-06-2017, 05:53 PM
Nice box blade! I also look forward to seeing how it works for you.
Old 05-06-2017, 07:02 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Hey Stan , you might have to stick that in the post so I can do my pebble drive
, looks the goods
Oz
Old 05-06-2017, 09:56 PM
We have had about three days of rain here in upstate NY with next week's forecast as more of the same. I will get some pictures of the blade in action as soon as the rain lets up. In between raindrops I played around for a couple hours on Friday and did a section of the driveway that was extremely hard packed that had grass/weeds growing up the center of the tracks. The blade and the scarifiers work really well. Pictures soon.
Old 05-07-2017, 03:33 PM
As requested, here are some pictures of the results of working the box blade. I made a total of 20 passes back and forth with the scarifiers down at the full depth, approximately 5" below the box blade cutting edge. Then pulling the material to the low spots and grading in, with the scarifiers up all the way. I attempted to roll the loose material in with the tractor wheels. What I really need is Dirty Steve's 1000 pound lawn roller.
The 2072 did a great job pulling the box blade. It would be better with wheel weights and chains on, because it would occasionally spin the wheels with the scarifiers down in the hard pan. As for final grade, don't confuse the quality of the tool with the skill of the operator! I'm still getting used to how quick the three point lifts and lowers under load.
Old 05-07-2017, 03:40 PM
Looks like it does a nice job, guess I need to buy one now.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-07-2017, 04:04 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Im amazed that 2072 will handle the 55" wide box! Looks good tho!
Glad to see someone making cat 0 attachments.. Not the one size fits none cat0/1 limited...
1- 1200 in pieces
1- 1864 in pieces
