I know this is an older thread bump. But, can anyone comment on the CH25 in the cub cadet. Was the shaft diameter 1-1/8" and not 1.4xx like Kohler says? I'm looking at a CH25 for my 782, but realized the shaft diameter according to kohler is larger than 1-1/8". I'm not familiar with what options might exist if the diameter is larger than the standard output size.
Red '84 Cub Cadet 782 50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd. |
So you plan on using the existing PTO from the K motor? If not, and have the PTO from the CH then it really doesn't matter as long as its the same size pulley... If its smaller it will spin the deck slower and vice versa...
My hope was to get a PTO from the CH25 series tractor, my concern is, Cub Cadet used a unique output shaft size, different from the standard Kohler size. 1-1/8 vs 1.4xxx.
According to small engine warehouse the CH25 in the Cubs came with 1-1/8", maybe they are wrong. Or, did Cub truly use a different size?
Kohler would make an engine however the customer wanted. Check the spec number on the one you are looking at to make sure.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
There is no "standard" output shaft size. Like Terry said, they were made to whatever spec the customer wanted. There are several different crankshafts depending on application.
Cub Cadet typically used 1 1/8" shaft, but there are exceptions. |
