Old 05-12-2017, 08:49 PM
GraniteState's Avatar
GraniteState GraniteState is offline
Default Deck ID Needed
Hi all!
I have a 127 that has a 42" deck with no id tag. I would like to get a shroud to help it clear the grass but there are three possible decks in the parts catalog...one that appears not to have a shroud at all.
I would like to know if anyone can tell me which 42" deck I have and/or if it had a shroud.
Thanks!
Kevin
Old 05-12-2017, 09:05 PM
Looks like you have this one:
http://www.cubcadet.com/equipment/AR...6-A/0062660004
Old 05-13-2017, 10:33 AM
athomas's Avatar
athomas athomas is offline
Expensive to buy, easy to fabricate from 1/16 x 1-1/4 flat bar from lowes. Bend material slightly outside of the radius of the blade ( you can reference the holes where the original bolted to the top of the deck if you don't have the pattern to copy ) and where the outer pc and center pcs meet ( I think that's about 7 inches or so off the back edge of the deck) cut them off,weld up the end and tack them to the deck or make up some L shaped pcs and bolt them on as the originals are. I think material is about 8-10 dollars it takes 2 lengths of the flat stock which they stock either 3 or 4 feet long ,been a year or so since I last made one so a little fuzzy on the detail.Just another option if your into fabrication !
