Old 05-19-2017, 11:57 PM
TexasP TexasP is offline
Default Cub 73 Restore
I am in the process, slow process, of restoring my 73. One of the issues that has me scratching my head at the moment is the dash tower. It has numerous rust spots/holes in it; some of which are in bends and seams. My question to those more experienced is, would it be best to try and find a tower in better shape to purchase, bondo or weld repair it?
Old 05-20-2017, 12:04 AM
Post up some pics of it so we can see how bad it is. Just depends. On a 73, battery acid may have leaked causing the damage. May not just be from rust.
Old 05-20-2017, 12:43 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Great question. I am redoing a 72 that had the same issue(s) with the dash tower. As J-mech said battery acid can badly damage it. In my case, battery acid and exposure to the elements caused significant pitting and over damage. I am having it powder coated and the dash would require extensive body work and expensive, difficult to use compounds to fill in the pitting. I found a donor model that is in great shape and will be cheaper and easier to refinish.
Have fun with your project!
Queen Of The Quietlines!
Old 05-20-2017, 10:30 AM
If I've done this correctly, I have attached two pictures of the tower.
Old 05-20-2017, 12:33 PM
I would try to find another tower from one of our sponsors or put an ad in the wanted section. Remember the 73 dash is specific to the 73 only.
Btw I think this thread should be moved to IH GT section
Old 05-20-2017, 12:53 PM
Old 05-20-2017, 01:22 PM
If you can't find a new one and are in need of professional assistance shoot me a pm.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-20-2017, 02:52 PM
PACubCadet's Avatar
PACubCadet PACubCadet is offline
Looks like quite the amount of damage, not too far to repair if you needed to however. Would probably be considerably cheaper to find a used one in better shape.
Cub Cadet 104, 107
Old 05-20-2017, 06:03 PM
I appreciate everyones tips. I've been digging around down here for one with no luck yet. Don't see as many 73's. I have a parts 100 that I have been using on my 70, but as y'all know, that's a different tower. I am going to pull the creeper off and put on the 73 though. As well as the K241.
Old 05-20-2017, 06:07 PM
PACubCadet's Avatar
Keep an eye out on Fleabay
Cub Cadet 104, 107
