Old 05-28-2017, 04:52 PM
Cubfan79dad Cubfan79dad is offline
Default Narrow frame hydraulic lift assembly
Resealing the unit
Where, how does the shaft seal go on?
It looks like there's some kind of bushing I'm afraid to knock out, nothing came off on disassembly
Old 06-01-2017, 12:28 PM
mattoney mattoney is offline
Pictures would help. Or a diagram. We'll try this and see what happens.
http://www.cubcadet.com/equipment/AR...0-A/0011200022
I think you are referring to Tag# 47, part number IH-347478-R91 "Seal, Hyd Pump Drive Shaft". Please let us know if what I'm thinking is right or wrong.
When I re-sealed my hydraulic unit, it appeared to have a bronze bushing in there. When I put a slide hammer in to pull it out, I found it was actually a rubber seal. The metal part of the seal and the pump shaft had rusted a little bit, and the rubber took on a bronze shade from the rust. That's what made it LOOK like a bushing. I cleaned up the housing and pressed the new seal in flush to the casting. I also cleaned up the pump shaft and lubed it before I put it all back together.
Hope this helps!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
