Talk me through adding front hydraulics to my 2182.... What all would be involved labor and parts wise.... Would it be worth the effort? I've got a line on a hydraulic angle blade for an SGT. I'm trying to decide if I should add front hydraulics, make the blade manual angle and sell the hydraulic setup, or an unknown third option.
I did a quick search, but didn't turn up anything that seemed to be what I was looking for.
1985 782 1974 Allis Chalmers 712S 1955 Allis-Chalmers WD45 |
MTD manual 772-4100A. Can't link the PDF here. If you PM me an email address I could. Or contact MTD directly to have them email it to you.
http://www.mtdproducts.com/equipment...&serialNumber= You need a second valve obviously. There is also a special piece that goes between the valves called a union fitting or adapter-valve- Part Number 711-3294. Can be found looking up a model 3100 or similar 3000 series and checking out the attachment to put extra valves on. Don't forget to get some hoses or steel lines made up. The cub fittings are not made in captivity any where that I have found. http://www.cubcadet.com/equipment/AR...A/769018860001 Part number 9 --> 711-3294 Get a bag of o-rings from Fastenal. I believe the instructions are also in the big Cyclops manual 772-4166.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Very straight forward. As Steve said, just a few parts. Took hardly anytime to add outlets on frond and back of an 1864 i have.
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Thanks guys..... the manual was a huge help. I can start gathering the pieces now.
I was almost thinking it would be simpler to add an electric valve and then use the single hydraulic valve for 2 functions (e.g. lockout deck and use in front). Thoughts?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
