Old 06-07-2017, 09:15 PM
Tony h's Avatar
Tony h Tony h is offline
Default 782 K17 Kohlar Points Cover screw size
My engine has both a fine thread and course thread screw in the points cover. Neither one fits happy. What should be in there? 10-24 or 10-32?
This guy sells an ignition to replace the Condensor. Too bad you still need the old style Points. They are a bear to get to unless, at the very least, take the complete air cleaner assembly off the Carburetor. I'd hate to drop those screws down the Carb throat.
http://www.kirkengines.com/index.php#RetainingScrewKit
If I can't fix it , it must not be broken
Old 06-07-2017, 10:45 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It uses a 10-24 screw. Use a baggie and rubber band over the carb to prevent dropping anything down the throat. Personally, I would use the basic Kohler condenser and points, set it according to the manual and forget about any special stuff.
Queen Of The Quietlines!
Old 06-07-2017, 10:51 PM
Just close the choke if your concerned, and the screws won't "fall" into the carb. because it is a horizontal throat, so a magnet tool easily retrieves them if they drop into the elbow.
use allen heads they are easier to install/hold.
