Old 06-09-2017, 05:20 PM
Dirty Steve's Avatar
Default 70 key switch
Found some conflicting data on key switches for a Model 70. Mine has a toggle switch in the appropriate key switch hole. Go to Cub website. Type in "70 &". Find Engine Controls and Instrument panel heading. Get the part number of IH- 403562-R2. Then there is another one for a tractor with a retractable starter. My 70 has the big starter/generator with the belt to the crank pulley. But then go to the heading of "Safety starting switch- Trctrs W/electric starters" and get a different part number IH-382458-R1. I want an original style switch. Just trying to figure out what it is supposed to have.
Old 06-09-2017, 05:54 PM
john hall's Avatar
Take a look at this on Steiner's website.
https://www.steinertractor.com/IHS11...h-w-1-keys-oem
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-09-2017, 06:09 PM
Option B. You could leave the wires hanging through the hole and just twist them together when you want to start it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-09-2017, 06:22 PM
There's no conflicting information on the site. You need item 5, part number IH-403562-R2. The retractable starter is a pull-start (retractable cord). The other part number you listed is for item 6, which is just the key. Finally, if you need a new push-button, that would be item 7.
Old 06-09-2017, 06:49 PM
Old 06-10-2017, 12:18 AM
Yep. Seems cut and dry.
Till one looks at this page.
http://www.cubcadet.com/equipment/AR...0-A/0098100012
Close John.... but the wrong one for a 70. The listing of tractors it fits is wrong. That ignition switch has a start position.
He needs this one for a 70.
https://www.steinertractor.com/IHS76...F=120613A3BA8D
Don't be afraid of Steiner. They are quality parts. Way cheaper than CCC or IH.
Old 06-10-2017, 12:23 AM
That's the set of and parts list for tractors with a neutral safety start switch. Does your tractor have one?
Honestly, I have never seen (on here or in the real world) a 70 or 100 with one....
Old 06-10-2017, 12:31 AM
That's for if you have the safety starting switch. You have the key w/ push button. So go with the part I gave you in my first post.
Old 06-10-2017, 12:34 AM
No, he doesn't have that. His pictures show the push button start, so he doesn't have the safety switch setup.
