Old 06-15-2017, 02:31 PM
jakeotter jakeotter is offline
Default Cub Cadet 72 upgrade to 10HP
Hi I have the chance to buy a running Kohler K series 10HP for $50. My Cub 72 with the 7hp is a fine little motor but wouldn't mind the couple extra HP.
Will that fit in my existing frame with little headache or is this a lost cause?
I'm not cutting the frame or any of that. Like my little Cub too much haha.
Thanks!
Old 06-15-2017, 02:35 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Pretty much a drop in if its a k301as
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 06-15-2017, 05:14 PM
What is this new motor from? Another cub? Blower housings were different on narrow and wide frame k series as the coil mount is lower on the narrow frame than it is on the wide frame and won't work unless swapped, also a few more subtle differences.
Old 06-15-2017, 05:24 PM
cubby102's Avatar
cubby102 cubby102 is offline
If the 10 horse is from another cub cadet it'll bolt right in. Only real difference will be your throttle cable. It's longer and connects differently on the k161/k181 engines. But it's a very simple fix.
And that is if it's a starter generator 10 horse. If it's a ring gear starter not so simple..
Old 06-15-2017, 05:59 PM
Wouldn't it be a K241? K301 is a 12 HP.
Old 06-15-2017, 07:04 PM
dvogtvpe's Avatar
K241. 301 will fit to.
Old 06-15-2017, 09:03 PM
Yep finally heard back and it's a K241 for $50
Old 06-15-2017, 09:33 PM
But what's it out of? If it didn't come out of a Cub then it will take some serious work to put it in.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-16-2017, 10:40 AM
Came out of Cub 100 series
Old 06-17-2017, 09:08 PM
johncub7172's Avatar
Thumbs up
I repowered my model 72with a k241 out of a model 100. Turned out great, no problems as I retained the model 100 wire harness and voltage regulator. Basically, I have a "newer" edition of the classic model 100!
Nothing like a all-gear drive, round fender IH cub Cadet, stronger than the hydro drives for sure!
Tags
cub 72, engine, kohler, repower, upgrade
