Old 06-23-2017, 09:48 PM
jimbob200521's Avatar
Default Saw this on another forum, cooling fan for Command by PTO?
I saw this on another forum while researching something else. Seems like a good idea to me, add a cooling fan to the PTO side of the engine to aid in cooling. Even if the difference made is minimal, a difference is a difference, right? Just wanting to get your thoughts on this as I wasn't able to track down part numbers or model numbers, etc. Would this work on our Cubs? Would we need a longer crank/different spec engine? Anyone have any info on the part number? I'd be willing to be a Ginny pig!
-Ryan
Old 06-23-2017, 09:55 PM
cubby102's Avatar
cubby102 cubby102 is offline
Personally I don't think it would do much if anything on a air cooled setup. Maybe it's to help cool the pto itself?
Or it is for hydraulic system cooling with a radiator in front of it
Old 06-23-2017, 09:57 PM
My thought was it would at least help pull some air over the side cooling fins on the engine as well as the oil filter along with the PTO. Again, I wouldn't expect a 100° difference but hey, even if only 5-10°, that's 5-10° less, right?
-Ryan
Old 06-23-2017, 10:07 PM
I would resist trying to out think the CC engineers.
Old 06-23-2017, 10:17 PM
Not necessarily trying to out think them, just aid in there intelligence
-Ryan
Old 06-24-2017, 12:04 AM
I wouldn't think there is room for starters. And "if" you could get it on, there wouldn't be any advantage, don't think it would do anything pulling air.
Might be better served if you decide to go out on the lake.
Old 06-24-2017, 12:32 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I believe that is a Simplicity Legacy, Agco Allis or Massey Ferguson 20hp or 25hp model.
Queen Of The Quietlines!
Old 06-24-2017, 12:57 AM
Terry C's Avatar
Terry C Terry C is offline
If you have the room I can't see it causing any harm. May keep your grill insert from melting.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-24-2017, 01:57 AM
So... you want to mount a fan on the front of the crank and blow air back toward the engine? You mean in the opposite direction that the fan on the back of the motor is blowing air.... thus working against it? So, now the air that was supposed to be directed out the front, just gets pushed back into the engine compartment. Yeah..... what could possibly go wrong....
Well.... Doesn't matter. If you look, you'll see the blades on the fan in the pic clearly blow air out the front. The model of tractor in the pic likely has a hydraulic oil cooler mounted in front of the fan. Better keep your Cub stock.
Old 06-24-2017, 09:16 AM
Come on man, I'm not that dumb! Why would I want to blow hot air back into the engine? Where did you even get that idea? it's obviously as you stated in your second paragraph, it blows air out the front
-Ryan
