Old 06-29-2017, 06:14 PM
swoodward83 swoodward83 is offline
Question I need some help
Hi there, i need some help. i own a few cubs, but am having some issues with one in particular. i have a 122, beautiful, but can not get it to start. it will crank over, but thats it. ive replaced the coil, condenser, points, battery, spark plug and coil wire. ive tested all the wiring, and they all seem to be good. i have noticed im not getting spark to my plug. but its a good plug. also, on my points, no spark...any suggestions would help me dearly!!!
Old 06-29-2017, 06:33 PM
this is my 122 that im having issues with...
File Type: jpg 18403780_1694682423894367_3322203006450437454_o.jpg (26.1 KB, 153 views)
Old 06-29-2017, 09:05 PM
Sievert456 Sievert456 is offline
Ignition switch? Also are your points gap properly?
Cub Cadet Original, Cub 147, Cub 125, 2 cub 1650’s, IH #1 Cart, tiller.
Old 06-29-2017, 09:07 PM
I put this in your other thread, didn't know about this one.
Sometimes you need to "deglaze" new points. However, first, Buy a cheap 12 volt test light and test for positive at positive post of coil during start. If present, next step is, While starting, probe negative side of coil while starting, test light should flash. If it stays on constant, points aren't closing properly, if light is not on at all, coil is open or points aren't opening properly and coil needs to be replaced/points adjusted. Let us know your findings.
Btw how did you set points? Need to use "static timing" method and not just gap them.
Old 06-30-2017, 10:22 AM
Next step for sure. This should tell you all you need to know.
Old 06-30-2017, 11:18 AM
What they said, plus the ignition switch may be faulty also,BTDT
Old 06-30-2017, 09:02 PM
Talking thank you all
thanks everyone. i will start tomorrow on all ideas given. im hoping to find the problem and hear this thing run, it hasnt ran since my father purchased it for me for a mothers day gift...
