Old 06-30-2017, 10:42 PM
h.d.fire h.d.fire is offline
Default 1450 "Mule Drive" or main drive belt for deck.
Hello guys,
New here so please forgive the likely dumb question...
I've searched through the "tech" page but couldn't find a number for the main drive belt for my 1450 tractor. I found, and ordered, the belt for the 44A mower deck but I need the one that goes from the PTO clutch to the main drive pulley on the deck.
Also if you guys can recommend a supplier that would be much appreciated.
Thanks in advance!
-Mike
Old 06-30-2017, 11:08 PM
bocephus1991's Avatar
I believe it's 117465 C1 3/8x79"
Brian
Old 07-01-2017, 02:38 PM
Thank you! That gives me something to go by. The BIG R in Morris, IL has a pretty good selection of belts, hopefully they'll have that size.
Old 07-01-2017, 11:35 PM
dodge trucker dodge trucker is offline
let me know as the Big R in Watseka had NO 3/8" belts.... I live right in between Watseka and Morris......
Old 07-02-2017, 06:34 AM
twoton twoton is offline
I use a 1/2" x 78" belt for my 1450 with a model 44a deck;
http://www.onlycubcadets.net/forum/s...686#post385686
works for me.
Old 07-02-2017, 08:33 AM
ya know, I have a 3/8" belt on there now (it is an OEM belt) but looking at my pulleys I'm thinking it could easily take a 1/2" wide one as the 3/8" does fit pretty "deep" within the pulleys.... though my belt was already a used one when I put it back on. I had to use up all my adjustment and could use a little more as things are....
Old 07-02-2017, 10:07 AM
I'll let you know what I find dodge...
Old 07-02-2017, 12:09 PM
You can find all the info you need on the Cub Cadet website. Here is a link to your deck, specifically for the PTO to deck belt. If you click the Add to Cart button for a belt, it'll usually give you the size on the pop-up window.
http://www.cubcadet.com/equipment/AR...0-A/0074200001
To find parts for your tractor, go to their website, click the link to Service & Parts on the right side, and type in your model number.
Old 07-02-2017, 04:11 PM
Thank you Lance! I ordered the belt and a few other parts I needed. Appreciate the info!
-Mike
Old 07-02-2017, 05:30 PM
-Mike
You're welcome! You'll find a lot of the general hardware and maintenance items are still available. However, larger and specialty items aren't available new anymore. eBay and the sponsors (at the top of the page) are usually good places to find those that aren't made anymore. If you're patient and can wait a little bit, you'll usually find a great deal on those sites.
Welcome to the forum!
