Hi all. On the model 149, the bottom end of the shift lever shaft contains some parts. Does anyone have a diagram of these parts? Also, the screw that holds the shaft in place, is that an adjustment screw for tension on the lever?
Well, it appears to be a plastic/nylon sleeve bushing on the end of the shaft with a spacer washer above it on the shaft with a c-clip on the bottom. The screw does not seem to be a tension adjustment.
Parts lookup can be done here.... Parts Lookup
That diagram is not what I have.
There are two versions for hydro control shaft (Roland's is the late version). The other version does have a nylon sleave. The screw/bolt is tightened to control the tension on the shaft.
I must have the earlier 129 tension bracket that is split, and has a tightening (tensioning) screw. This bracket broke on the P.O., and I have been dealing with this hydro surging for awhile now.
Does anyone have, or know of a place that makes this bracket as a replacement ? |
