Old 07-07-2017, 02:29 AM
Wageslave Wageslave is offline
Default 2084 Engine run-on
I am having some issues with my 2084 dieseling on after it gets up to operating temperature. It is running and starting quite well with no smoke, but when I go to shut the machine off it will continue chugging on for as long as I let it keep going. If I pull the choke out, it will die within a second or two. The motor does not seem to be excessively hot, and I usually blow the mower out with an electric leaf blower after each use
It is not a terrible issue to deal with, but I have got almost everything else fixed and I would love to scratch this off the list too.
Thanks
Old 07-07-2017, 06:24 AM
Fuel shut off solenoid in the carb isn't working. Also likely it is running a little lean too. Probably best just to pull the carb and clean it and replace the solenoid. **Do check the wiring to be sure the the power going to the solenoid is being cut when the key is turned off.
Old 07-07-2017, 07:40 AM
bugeye bugeye is offline
The carburetor solenoid is on the firewall side of the carburetor. It should click when the key is turned on. I sometimes have the same shutdown issue with my 1864, 18 horsepower Kohler. I turn off the key while simultaneously pushing the throttle wide open. Seems to shut down with out dieseling most times. Don't forget to return the throttle to idle after the engine stops.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
