Old 07-08-2017, 07:49 PM
Default Homemade weight's
I got these weights on a 124 I picked up a while back, they fit inside the wheel and I thought they may be from another brand. I started work on the tractor yesterday and the first thing I did was pull the weights off, it turns out they are homemade but very well made. I got a bit of a surprise when I took the first one off, they are solid lead and weigh 55lbs each. It looks like they were cast using a cast iron skillet, they are tapered on the sides and you can see the pour spouts sticking out the sides. These will look nice painted yellow on the 128 for when it get the loader.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-08-2017, 08:08 PM
twoton twoton is offline
.... they are solid lead ....
Hmm..., that's an idea. To bad I just gave all my lead to the black powder guys at The Club.
Old 07-08-2017, 08:13 PM
That much lead may be hard to come by these days, people use to give it away but then it became valuable but that may be over since the price on scrap is down.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-08-2017, 10:56 PM
john hall's Avatar
Neat weights. I don't know about lead prices, a while back one of the auto stores was paying $20 ea for full sized batteries. The other stores were paying $10. I need to check as we have about 4 to get rid of.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-08-2017, 11:46 PM
The bottom 4 weights are lead. I used a cake pan for a mold and drilled the hole in the center with a 1" drill bit. I think they are about 26 or so pounds each. They work really well.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 07-09-2017, 12:06 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Nicely done! Had a buddy that used to collect used wheel weights from the tire stores.. He would make all kinds of sizes and shapes of weights for the pullers around here.. I was always scared to go over there when he was melting lead... had all kind of green fumes spewing out the back door of his shop when he did it..
Jay
Proud owner of the following:
Old 07-09-2017, 01:13 AM
Those'll look good cleaned up and painted. I see the resemblance of the fryin pan, good idea.
Old 07-09-2017, 06:17 AM
cubby102's Avatar
cubby102 cubby102 is offline
I've been playing with the idea for a long time of making a sand cast of a ih weight out of pure lead or a "stronger" mix. I did the math once before and they really wouldn't weigh a whole lot more iirc it was less than 15 lbs.
I've also played with the idea of using a old wheel as a mould to make a "fitted" weight that would sit down flush with the back side of a valve stem which would still allow a ih weight to be bolted on top. Just haven't gotten around to gathering the lead. Only have maybe 80 lbs at the moment
Old 07-09-2017, 08:33 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
My 1872 came with these. I wander if I could make a plaster cast of a wheel weight and re-pour?
