Old 07-09-2017, 08:48 AM
drcjv's Avatar
drcjv drcjv is offline
Default Problem no one can figure out
In have a 2072 that would not run after 15 20 seconds. After talking to lots of people, dealers still can't figure it out. I have replaced the fuel pump and rebuilt carb. finally got it running yesterday but, this is the third time overnight the oil has filled up with gas. After the first two times I was told it was the fuel pump ( I changed it) after the second time I was told it was the carb (changed it) still when I went out today the oil again was full of gas. I even took the carb off another running 2072 and this still happened.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 07-09-2017, 09:13 AM
Berwil's Avatar
Berwil Berwil is offline
Isolate the 2 components. When you park it, disconnect the pump to carb fuel line and cap it. If it doesn't fill up with gas in a couple days, bypass the pump and connect fuel line directly to the carb (with a full tank of gas). Which ever way fills up the crankcase with is your problem.
Bill
Old 07-09-2017, 09:15 AM
CubDieselFan's Avatar
I would put a electric fuel pump on. I do that on all my mags.
Old 07-09-2017, 09:34 AM
bugeye bugeye is offline
Well the gas is coming from somewhere. Could it be the fuel line is shedding particles and now has caused the carburetor float valve to stay open? Has the fuel line and fuel filter been changed?
I had a similar oil problem. I pulled the fuel tank and cleaned, then changed all the hoses and fuel filter on my 1864.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 07-09-2017, 10:09 AM
And it only takes a thin hair to hold the needle off it's seat and flood into the crankcase.
you need to do some detective work
Old 07-09-2017, 10:14 AM
Old 07-09-2017, 11:08 AM
flatpickerray's Avatar
flatpickerray flatpickerray is offline
Are you sure your neighbor isn't coming over at night and pouring gas in oil fill tube?
Old 07-09-2017, 11:14 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
To add insult to injury, he's probably siphoning it from the mustang.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-09-2017, 11:30 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Fire hazard waiting to happen! I'll come haul it off to save your family and other toys. NO CHARGE. If not try this. I have them on all 3 of my Cub's.
Old 07-09-2017, 12:45 PM
drcjv's Avatar
Ok I'll be setting up a camera tonight to see if my 87 year old neighbor is the culprit and I'll put a locking cap on the mustangs. If it is the carb it has happened with two different carbs the same is true for the fuel pump as I changed them out twice. I will clean the tank and replace the lines and filter this week.
2072 50" deck
