Old 07-09-2017, 09:31 AM
CubDieselFan's Avatar
Default 1998 Chevy will not start
My 1998 Chevy, K2500 has been hard to start for the past year. I do not drive it much so it has not been too much of an issue. Now it will not start. After it started for the first time at the start of the day, it would start easy the rest of the day. It turns over good but will not start. I do not like throwing parts but a coil was only 31.00 so I thought I would give that a try. I will try that after Church. Friday when I was trying to get it to start I could smell gas like it was flooded so that is when I stopped trying to start it.
Forgot to add, it is a 350 vortec. 174k miles.
Old 07-09-2017, 09:51 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Check fuel pressure. Those engines will not start with less than 55psi. Fuel pump would be the most likely fix. Possible fuel pressure regulator leaking as well.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-09-2017, 09:59 AM
If you are smelling fuel, you could have a rusted fuel line, they are known for that problem, as well as brake lines as they run together side by side along the frame in the nylon holders.
Old 07-09-2017, 10:17 AM
It's a Vortec motor. Not Vortex.
Old 07-09-2017, 10:52 AM
Ha,LOL yer right
kind of like a klub kadet with a Kroller injin'
but the "X" is next to the "C" on the keyboard, so I'll give him the benefit of the doubt.
Old 07-09-2017, 10:54 AM
This is kind of like a thread stating a Cub won't start with no other information. Nothing to go on.
A list of possibilities looks like this:
Low fuel pressure
-Bad fuel pump
-Faulty fuel pressure regulator
-Plugged fuel filter
-Hole in fuel hose under intake manifold
-Faulty fuel injection "spider"
-Leak if fuel line from tank to motor
Vacuum leak
-Upper intake gasket leaking/ or warped plastic intake. Could also be a leak at the grommet/o-ring on around the fuel injection "spider". Or a cracked/broken fitting on the PCV system.
-Plugged or failed EGR valve.
Timing issue
-Bad/ worn distributor or drive gear
-Worn camshaft gear
-Worn timing chain
Sensor failure
-Crank sensor
-TPS
-MAP
I have seen all these.
Could even be a bad ignition switch. Or a power failure on the ignition circuit to the PCM. Lots and lots of possibilities..... you're going to have to narrow it down. I'd start with a fuel pressure check, as was already suggested. But, at 175K...... it could be a lot of things.
Old 07-09-2017, 10:57 AM
Ha,LOL yer right
Yes, but I see this all the time. Especially on C-list. It's a pretty common misspelling. Kind of like the people who have a Cummings motor. Sorry boys, there is no "g" in Cummins.
Old 07-09-2017, 11:09 AM
I fixed it. I think my iPad did the auto correct.
Old 07-09-2017, 11:11 AM
It happens, LOL.
Old 07-09-2017, 11:48 AM
I have a fuel pressure gauge so I will test it this afternoon. I can hear the pump run but that does not mean it is enough.
