Old 07-09-2017, 05:16 PM
bluesman bluesman is offline
Question 18 hp Kohler Command
My kohler command loses power and misfires once it's warmed up. Any one else have this happen? Tia for any ideas on things to look at.
I will attempt to address my procrastination problem while you wait.
Old 07-09-2017, 06:42 PM
sorner's Avatar
sorner sorner is offline
First place I would look is the coils.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 07-09-2017, 06:50 PM
Times 2
Old 07-09-2017, 08:36 PM
john hall's Avatar
If the ignition check shows OK, how about a valve sticking once the engine is warm? Might be helpful to know how long it has to run and if it is a solid or intermittent miss.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-09-2017, 08:59 PM
Carb, cooling, ignition, compression, fuel etc.
Old 07-10-2017, 11:54 AM
Thanks for the input. I was going to start with the carb but since it's been mentioned I go at the ignition first.
Old 07-23-2017, 11:20 AM
Can I access the coils without removing the engine?
Old 07-23-2017, 11:25 AM
You make no mention of the model of the tractor you are working on, so that is hard to say.
It is far easier to just pull the engine and remove the shrouds. It gives you a good opportunity for a full examination of that area, to clean the Fan and Shrouds, and make any repairs as necessary.
Old 07-23-2017, 05:01 PM
Smile
The tractor is a 2185 built in 94. It probably does need a real good cleaning.
Old 07-27-2017, 09:51 AM
sorner's Avatar
Yup, pull it and remove the shrouds and look around. Save your knuckles. It's not terribly hard on the 2185 to get the engine off, but you might have trouble getting the exhaust apart to release the engine. I had two that I tore apart, both were rusted. The pipe was rusted and wouldn't come off the muffler inlet, and the bolts were rusted where the muffler is attached and the bolts broke off. New mufflers are pretty expensive for that. If that comes apart easily, the rest is a piece of cake.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
