Old 07-14-2017, 06:43 AM
Kestrel Kestrel is offline
Default LT2 NR92 drive problem
It's the hydrostatic version. I'm not sure if this model number is a UK variation only, but I have a drive problem.
After the tractor has been in park, even if only for a couple of minutes, when I disengage the brake and press the peddle to go forwards, I can feel slight juddering and hear the belt spin, but it don't move. Same applies to reverse also. If I pump the pedal either forwards or reverse, it does start moving after 5 seconds or so.
I think it could either be a stuck brake pad or perhaps a slack belt, however once it's moving, I have no issues with speed.
That tractor was bought brand new from a registered cub cadet dealership last month. I would take it back to the dealer for them to take a look, but it will cost me the best part of £50 to do this due to living on an island and needing to use a ferry. If I can, I would rather try and fix it myself and save my money.
Would this void my warranty? I have worked on lawn tractors before, but never a hydrostatic version. Before I start stripping all the guards off the cutting deck, can anybody advise on where exactly I should be looking on this machine please? Is it much different to a transmatic lawn tractor underneath?
Old 07-14-2017, 08:50 AM
First, welcome to OCC.....
It would appear that the LT2 is an export model.
For our members, here is the LT2.... https://www.youtube.com/watch?v=7IXvdv7KJAw
From the sound of things, I think you are right. I would venture to say something needs lubricating, or some adjustment needs to be made.
Old 07-14-2017, 11:13 AM
CubDieselFan's Avatar
How much did the mower cost? I might ask the dealer could they send someone out to adjust it.
Old 07-14-2017, 12:51 PM
Thanks for the welcome.
Mower cost £2200. Dealer won't send somebody out. Because it came with 3 year warranty, I asked them when I bought it and they said I would have to return it to them for any repairs. If it is something I could remedy myself, I'd rather save my money if possible.
R Bedell
So do you think it's most likely the brake sticking or is it the belt too loose? If I do the work myself, will I void my warranty?
Old 07-14-2017, 02:26 PM
I tried pulling up a Parts Diagram at the Cub Cadet site here in the States. It stated no such model found. So, I can only venture and educated guess. It "sounds" like the brake is hanging up, perhaps not allowing the belt to travel freely, hence the noise from the belt.
I do not know the laws in Scotland, but here in the States, if a company finds out that and "unauthorized" repair was done, they may go as far as voiding the warranty, depending on the situation and extent of repairs.
Old 07-14-2017, 03:51 PM
Thank you for getting back to me.
I will have a look at the brakes this weekend and see if that is the problem. If I just need to add a bit of grease or tighten a nut, I will probably get away with doing it myself. But if that doesn't help, I think I'm going to have to bite the bullet and take it back because I don't want to invalidate a 3 year warranty on a brand new mower.
I have had a look around on cub cadet sites and it is advised to check and adjust/tighten nuts periodically if they come loose from vibration. I can't see how this repair would be much different. I don't understand why a machine this new would have loosened its nuts though, unless they weren't tight enough to begin with. It's been running less than 15 hours in total.
Old 07-14-2017, 04:14 PM
Anything is possible, but I am guessing more along the lines of a Linkage Rod that is out of adjustment, or needs lubrication.
Old 07-14-2017, 04:21 PM
I was on a European Site and they are asking for a 11 digit model number. What is your Model Number as seen on the Chassis Tag..???
Old 07-14-2017, 05:34 PM
I don't know, I'll have a look tomorrow and let you know if that's okay?
Old 07-14-2017, 07:01 PM
No problem.
