Old 07-22-2017, 08:01 AM
twoton twoton is offline
Default Cyclone Rake Commercial Pro
Last fall I bought a Cyclone Rake Commercial Pro. I know there are other makes and models of leaf collectors and I cannot advocate one over the other as I have no experience with any other units. I will say that I am happy with my purchase. I ordered it late in the fall and received a healthy discount.
The unit was delivered promptly. Assembly was quick and I was cleaning up the wet and frozen leaves promptly.
I did have my boys raking along with me to get the edges and loosen the frozen stuff. I was very happy with the performance of the unit and know that come this fall, cleanup will be even easier as I will be going at it earlier in the season.
Old 07-22-2017, 08:04 AM
Lately, I’ve been using the Cyclone Rake as a grass catcher. I have some areas that are in need of mulch and the grass clippings have been working quite well.
Old 07-22-2017, 08:06 AM
The only thing, thus far, that I have been unhappy with, is the manner in which the unit attaches to my tractor. This type of leave vac attaches in a semi rigid manner to the rear axle housing. Thus, creating an extension to the frame of the tractor, which, at the rear, rides on casters. The front of the leaf vac frame has two “forks”, which attach, using two hitch pins, to a draw bar plate that is supplied. This setup allows for enough play to accommodate uneven terrain while keeping the unit rigid along the length of the tractor.
Old 07-22-2017, 08:08 AM
I really did not care for all of that weight and torque being placed on the bottom three bolts, or in my case studs.
Old 07-22-2017, 08:11 AM
So, I made a hitch adapter from some;
½” x 2” flat stock
2” x 2” x 3/8” angle
½” black pipe
Old 07-22-2017, 08:15 AM
This adapter allows me to utilize the added strength of my “Extreme” hitch and also quickly move the vac to other tractors. In my case, between the 1450 and 1650. Initially I was going to use pins that I made from some ½” bolts but decided that a couple of 3/8” wired hitch pins worked even better as they were easier to install on uneven ground and allowed some additional play between the tractor and the leaf vac frame. Time will tell how this all turns out but for now I am quite happy. Use at your own risk.
Old 07-22-2017, 06:59 PM
Terry C's Avatar
Terry C Terry C is offline
Looks great.
I got a trac vac with a 125 awhile back. The old guy that had it used two blades per spindle, 90deg offset. I've never tried it.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-23-2017, 08:09 AM
Looks great........
Thanks Terry.
.......The old guy that had it used two blades per spindle, 90deg offset......
Sounds like mulching blades, old school.
Old 07-23-2017, 08:34 AM
john hall's Avatar
Nice looking setup! Glad I don't have enough leaves to worry with.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-23-2017, 08:08 PM
Originally Posted by john hall View Post
Nice looking setup!......
Thanks John.
You're a lucky man. More time for the important things.
