Advance Auto is having a 20% off sales this weekend (25% if you order online). Shell Rotella T 1 SAE 30 before discount is $14.99 for 2 gallons. And the Shell Rotella T 1 HD SAE 30 is $14.99 for 1 gallon. Is one better than the other for the Cub Cadet 1210? Thank you in advance!
This is what Cub Cadet and Kohler recommends. It is your tractor, your time, and your money, you can use what you see fit.
http://www.onlycubcadets.net/forum/s...ead.php?t=4637
As Mr Bedell stated, your tractor, your money, but I would not use it in my air cooled engine. So 2 votes for using what the manufacturer recommends.
Of course the manufacturer is going to recommend something they sell, that's just good business and keeps the cash flowing in their pockets. It's just like Ford recommending motorcraft oil but nobody would hesitate to run whatever brand they preferred. Use whatever you want, I run Valvoline in all my engines and have never had an issue.
DON'T DRINK THE CORPORATE KOOL AID.
I use Rotella in my stuff.
Same here. Just what the OP stated too, 30wt.
I run Low-Ash oil from CaseIH. Price isn't too bad in gallon containers. Even if it does cost a couple bucks more, how often do you change oil in a years time in a lawn mower, twice at the most?
On a related note, we switched from Exxon Super HDII to a Dello equivalent this spring for all of our older gasoline farm equipment. I don't know offhand what it is, but its a 30W specifically listed for older engines, no problems so far. Sole reason I switched was convenience purchasing the oil.
I have used the Shell Rotella 30wt but recently switched he'd Valvoline 10w-30 conventional. Just follow Cub/Kohler's recommendation for oil weight and season and you'll be fine.
-Ryan
I run 30wt Rotrella in a couple. Not one problem.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Rotella 30wt here too.
102 soon to be tiller machine 108 mower 73 plow machine 169 soon to be mower 122x2 now parts machines Parts 129 149 parts 61 "O" 104 job to be determined ![]() ![]()
