Old 07-22-2017, 05:54 PM
jon81SC jon81SC is offline
Default Location of voltage regulator on 1210?
Where is the voltage regulator located on the 1210? Was unsuccessful with a google search and couldn't find it on this site. Thank you in advance.
Old 07-22-2017, 06:31 PM
cubs-n-bxrs's Avatar
Should be mounted on the flywheel shroud next to the coil. It's a rectifier/regulator. It has a 3 prong connector on it.
Old 07-22-2017, 06:38 PM
Yes and no. Located on fan shroud passenger side but just by itself, no coil there as it's a mag engine. Connector with 3 wires going to it.
Old 07-22-2017, 07:56 PM
The early 1210's had a coil and point system, the vr is located where the others had replied.
Old 07-22-2017, 08:18 PM
There were two productions of the 1210. The early model had a Kohler K301 engine, while the later production had a Kohler M12.
Both used this Voltage Regulator/Rectifier which was located on the Fan Shroud.
Old 07-22-2017, 09:05 PM
This is a Mag12 out of a 1210
Old 07-22-2017, 09:26 PM
Why did you guys have to say that? Now I kinda wish my 1211 was an early one with points.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 07-22-2017, 09:46 PM
Easy to swap out Tim.
Old 07-22-2017, 09:50 PM
Yeah wow learn something new every day. Just rebuilt my M12 and lots of parts are k301 but didn't know a points version 301 was available in that series. Makes sense
Old 07-22-2017, 09:58 PM
But you have to change the wiring. ....
Change the pto and such....
