Old 07-27-2017, 06:58 PM
Workinprogress Workinprogress is offline
Default Garden Plow Guidance
Started looking for a used garden plow for my cub. I know nothing about plows.
I found one but the setup seems a little different than the Brinly ones I see elsewhere. The angle adjustment is by the front of the plow instead of in the rear.
Anyone used a plow like this?
Should I just keep looking for a brinly or other brand?
Any suggestions would be appreciated. Thanks
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 07-27-2017, 11:21 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I think that is a Sears or Roper plow.. It should work just as well as the Brinly.. doesn't really matter where the adjustment is.. That controls the angle on the point and helps determine how deep the plow runs.. If you shorten that upper link the plow will run deeper.. if you lengthen it should run more shallow.. Same principle on the brinly or any turn plow (moldboard plow) for that matter! They are easy to use and a lot of fun to plow with when set up and adjusted correctly!
Jay
Proud owner of the following:
Old 07-27-2017, 11:40 PM
At least hook it up, and see how it "looks" on fit. But as Jay said, there all the same, for the most part.
Shine the face up, oil up the adjuster, and give it a whirl...
Old 07-28-2017, 07:47 AM
cubs-n-bxrs's Avatar
I've seen numerous plows like that at the different plow days that I have been to and they work just as good as a Brinly. If the price is right grab it. It's all a matter of getting them dialed in.
Old 07-28-2017, 02:19 PM
Asking $100 but they have been trying to sell it for a month.
1711 with KT17
104
Old 07-28-2017, 03:11 PM
Merk Merk is offline
I owned and plowed with a plow like that one. My plow has a Sears id tag on it.
It is a good plow as long as the point is good and the coulter turns.
A good way to if it has a good point is to put the plow on a cement floor and check to see how much gap there is behind the point.
Bad thing about the plow there is no replacement parts for it.
Project Uncle Dick
Cub Cadet 70
Old 07-29-2017, 12:46 AM
jaynjeep's Avatar
That is a good price.. you won't find a Brinly that cheap
Jay
Old 08-04-2017, 05:13 PM
Thanks for all your help!
I picked up the plow today. Turned out to be in pretty good shape. Angle adjuster was frozen but after some pb blaster and a pipe wrench was able to free up the adjuster.
Time to weld up a sleeve hitch adaptor for tractor!
1711 with KT17
104
Old 08-04-2017, 07:55 PM
Here are a few close up photos of the plow.
1711 with KT17
104
Old 08-04-2017, 11:04 PM
jaynjeep's Avatar
Glad you picked it up!! Time to turn some dirt and shine it up!! and send us some pictures!
Jay
