Old 08-12-2017, 11:50 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Default 127 hydro issue
This is not my personal tractor but my uncles 127 he just got it last weekend it looks very nice has electric lift and runs/mows good we was running it today we mowed about 2 hours with it and all went well then suddeenly it just would not move either dierection motor was running but when you move the speed control lever nothing no noise no excessive play or tension
I looked underneath all linkage was intact and moving as it should (he worked handle and clutch while I watched down below). There is no evidence of oil loss clean no leaks underneath.
I suggegested he change the filter and oil my theory was we got the fluid good and warmed up today and may have stirred up dirt or sludge in the oil. The prevois owner was mowing with this machine but had a small yard and this is probably the longest its been run in awhile.
I was just wanting some other input and ideas as to the nature of the problem.
Ive been trying to get my uncle to join OCC he collects them as well he actually helped me get started with all the tractors
Old 08-13-2017, 01:40 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Check the driveshaft and make sure it's turning the pump.
Plow blade
#2 Cart
QA36 snowthower
Old 08-13-2017, 02:36 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Definately check this. It could have sheared a roll pin. Though I've never had this happen on a hydro. I have had filters get slammed clogged after running a while. Good luck with it..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-13-2017, 05:06 AM
cadzag72 cadzag72 is offline
It sounds like the dowel pin sheared. At the back oh the engine, there's a slotted drive hub where the driveshaft slides in. A solid dowel pin fits into this slot and is what sends the power to the hydro. As the cubs get older, these slots in the drive hubs widen, allowing the engine to act like a hammer on the dowel pin. They are cheap and still available, so just replace the pin. Make sure to use the right part, if you cheat and use a bolt or a roll pin not only will it break again soon, but it will wallow out the hole in the driveshaft the pin goes into. Support the driveshaft, use a punch and hammer to drive what's left of the old pin out, and then put the new pin in. Good luck!
Ian
Old 08-13-2017, 07:46 AM
flatpickerray's Avatar
flatpickerray flatpickerray is offline
I agree with all the above. This happened to my 129, I got a cheap hardware store roll pin and it didn't last long. Order the correct pin as I did and you'll be a happy camper.
Old 08-13-2017, 09:19 PM
Ridingmowers1 Ridingmowers1 is offline
We're is the best place to get spiral pins ? Fastenal?
Old 08-14-2017, 04:07 PM
cubs-n-bxrs's Avatar
McMaster Carr is where I get coiled spring pins.
Old 08-15-2017, 12:25 AM
johncub7172's Avatar
Its a solid, hardened pin, btw.
Old 08-15-2017, 04:13 PM
What he said.
Old 08-15-2017, 05:32 PM
charlie105's Avatar
charlie105 charlie105 is offline
Default Dowel Pin
Ditto on the pin. It is a ¼ x 1 ¼ in. dowel pin. I sheared 2 roll pins in succession several years ago….PITA ! (didn't read the shop manual)
