Old 08-19-2017, 02:25 PM
D50ffe D50ffe is offline
Default Hello from Glen Allen, VA
Found a 1970 147 that was a single owner tractor stored in a barn. It was last used 2003 and was very well maintained by its first owner. The 147 came with all original paperwork, manuals, owners notes, a deck, supporting frame, rake and cultivator attachments. It has taken me a few months to get it running as the fuel tank and carb were filled with old fuel/sludge and the wiring harness was toast. I have enjoyed reading the posts on this site and look forward to contributing. I want to know is it really necessary to remove the engine to properly install the new harness?
Old 08-20-2017, 01:07 AM
NO, you do not need to remove the engine for wiring replacement on a 147. Where did you come up with that?
Get hold of Mike Lamar for the replacement harness. He's a member to OCC, and his harnesses are second to none.
Oh, and welcome to OCC...
We like pictures you know.
Old 08-20-2017, 07:08 AM
Welcome to the forum. Lots of info here and the 147 is a great machine!
Mikes harnesses are the best.
Here you go
http://www.onlycubcadets.net/forum/s...ad.php?t=34457
Old 10-23-2017, 11:25 PM
Smile Learned enough to know I've not learned enough
Thanks for your comments and suggestions. Since my initial post I have installed a new wiring harness and have proven that it is difficult, but not impossible, with a little common sense. I used the old harness as a pull for the new harness around the flywheel. One of my lessons learned was checking the solenoid mount for a good ground. Since then I have been using the tractor and the rake attachment. My next move is to determine the best way to adjust the hydro. I've been reading the comments on this site to help me figure it out. With a narrow frame , I've got to do it from below and it does not sound easy with the tractor running and me underneath. I'll ask the folks on the site what techniques they have used over the years to accomplish this adjustment.
