What is happening is the tractor (2135) will stall while cutting. I have to wait anywhere from 30 mins to over an hour before it will start again. What is strange is when I hear it dogging, and I disengage the PTO it will keep running. It still dogs for a while, but won't stall. If I re engage the PTO after a couple of minutes it will dog and stall if I don't disengage it. If I wait for a while and start cutting again it will give me more than a couple of minutes cut time ... more like 20 min. I have the gas cap loose because it causes the it to stall if I have it on too tight.
Any idea what I need to do to correct this? Thanks for reading my post.
2135 Model:13A-214F100 Serial:371415 Kohler Engine Family:SKH398U1G2RA Model:CH13S Spec:22508 Displ(cc):398 Serial:2705208184 |
Gremlens. Gremlens are infesting your tractor. Better sell it fast!
Do you want a list of the 10 or so obvious possible causes? Have you done anything other than loosen the gas cap to try to fix it, or figure out what's wrong with it? Do you know how to go about performing ANY engine diagnostic tests? Or do we need to walk you through a complete diagnostic procedure, because you basically just said, "My tractor doesn't run, what's wrong with it?" We need more information if you have it! |
![]() Quote:
![]() ![]() Come on guy, we all want to help get your tractor going, but we also need to know what, if anything other than loosening the gas cap has been done to it.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Let's make a guess contest! I bet his deck spindles bearings are shot, kaput, done for good! So they overheat, almost stall and kill his engine.
I'm sure a 5 gallons of gas and a match can take care off it. ![]()
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Well after careful consideration of all the facts presented,
I come to this conclusion: the valves are valving, the carburetor is carburating, the spark plugs are sparking and the crank is cranking, but the pistons are not pissin! so it needs a new piddle valve. ![]() |
You guys have way too much free time.
Come on guys, this Lady is trying to find out what is making her tractor stall. True she didn't give much info, but to someone new to this stuff, there is no use in making fun of her question.
Spirittoo Give us more detailed info and i'm sure someone will be able to help you.
[B]Larry[/B] |
![]() Quote:
We all asked for more info..... haven't gotten any yet. ![]() And she hasn't logged in since posting this question. Hard to help if you don't come back and converse with us. |
![]() Quote:
Sorry I haven't gotten by sooner something came up that I had to deal with. Anyway ... I don't know what else I can tell you. I didn't try anything else because I didn't know what else to do that would help. I tried cleaning the carb before but that didn't help. The only thing that did was loosing the gas cap which solved the problem for a while, then it started acting up again.
What about the PTO and disengaging it stop the stalling? Most seem to be too busy ridiculing me to comment on that. Perhaps if you ask me some more questions I may be able to answer or find out if I can get an answer. I'm not a expert ... just an old woman trying to keep an old tractor going because I can't afford another one. ![]()
