Old 08-24-2017, 07:42 AM
bfowler88's Avatar
bfowler88 bfowler88 is offline
Default Single cylinder kohler 14HP or 16HP in a 682?
Hi guys, I need an engine for my 682 and most say not to bother with the KT17. I was thinking why not swap in a single cylinder 16hp engine from a 1650 or even a 14hp single from a 1450? They are both wide frames so it seems like it would be a easy swap. Let me know what you think. Seems like I could find those much easier and cheaper then a newer KT17 or magnum 18 etc....
1971 IHC Cub cadet 106
1982 IHC Cub Cadet 682 (looking for engine)
Old 08-24-2017, 08:19 AM
It will work but it will have noticable vibration compared to a twin cylinder, I have a 1211 which is basically a 782 with a 12hp single and it's definitely not as smooth as twin but is tolerable in my opinion.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-24-2017, 09:52 AM
bfowler88's Avatar
Yea the vibration don't bother me, The 106 doesn't bother me so I'm sure it would be fine. Will the electric pto clutch bolt right up and the driveshaft also or is some modification going to be required? thanks!
Old 08-24-2017, 09:56 AM
If you are patient, you will find a good series 2 or magnum.
Do not wast your $$ on a series 1 as a replacement.
I have 2 spare magnums, one I built from parts and another that was given to me by a wonderful member here.
They are not for sale, but just proving they are out there, craigs list, epay and others.
Hopefully other members here will post what cub models will fit, I think the cyclops series will fit and if you are willing to go with the newer "V" twin style, there are retrofit kits but they are a little pricy for some ppl but there are also used ones.
Old 08-24-2017, 10:00 AM
The most noticable difference between the 106 and the 682 is all the extra sheet metal on the 682, once the sheet metal starts vibrating it gets pretty loud. I spent some time on my 1211 trying to reduce it as much as possible and have it to the point where it's completely tolerable.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-24-2017, 10:08 AM
bfowler88's Avatar
The retrofit kits are out of the question for now, I cant see paying that much for a mower engine. I have seen the magnums online but they are 4-500 plus. Maybe I will get lucky ........
I guess the extra metal would cause more vibration, how did you reduce the noise?
Old 08-24-2017, 10:14 AM
Leadslingingdaddy's Avatar
Watch for other brands with the Mag in them.... Sears put them in a lot of there GT's... Just make sure the shaft is the same or use the pre-existing PTO....
Old 08-24-2017, 10:22 AM
Do post to us here before you possibly purchase another engine as there are a lot of models of mags & series 2 that are different specks, that will not work for one reason or another, crankshaft diameters and lengths are just 2 that come to mind.
Luck with your search.
Old 08-24-2017, 10:45 AM
I cut fuel tubing and glued it to the grille housing towards the top of the side panel, that was a pretty noticable difference by itself. I also squeezed the hood a bit so it was tighter to the dash, other than that I basically just checked everything over to make sure everything was tight.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-24-2017, 12:37 PM
That would be weird....a red one puttering and shaking like a yellow one...
Might be sorta cool. I'd like to see it.
