Old 09-03-2017, 10:18 PM
lawman lawman is offline
Default 129
I have a 129 with no motor , I want to know what would be involved in using a 16 hp kohler motor from an AC 416 garden trac, the 16 has a electric clutch pto, which wouldn't be a problem other than belt difference, what I was concerened about is motor mount holes, and the oil pan is about an in. taller, and difference in wiring as the 16 has a different type starter
a c
Old 09-03-2017, 10:24 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The AC engine will not work in the 129. It uses a different oil pan configuration. The starter and charging systems are different too. IIRC, the crankshaft is a different size.
Queen Of The Quietlines!
Old 09-03-2017, 10:58 PM
