Old 09-04-2017, 11:37 PM
tmx43 tmx43 is offline
Default Kohler M16 in wide frame
I have a Kohler 16 Magnum engine I'm trying to mount in a 1200. I'm missing the bearing plate and all ignition parts. The small bearing plate does not have a mounting bracket for ignition. The large plate has a starter mount but will not fit the wide frame from what information I have. Could someone point me in the right direction for what I need. I do have the M16 flywheel with no fins on it.
thanks for any advice.
Old 09-05-2017, 08:12 AM
I told you in your other thread that you need to find a K series for that puller. You can't adjust the timing on that Mag motor. You'll be very disappointed after all that work, only to find out you can't get much power out of the M because of it's fixed timing. Go find a K series.
The larger bearing mount WILL fit into a QL frame. No different than the K341's in the 1650's. Don't know who told you the M won't fit, but they're wrong.
Old 09-05-2017, 11:20 AM
ok thanks for the info. do I understand that the m motor cannot be turned in to a k with mods? I thought that a new ignition system with a steel flywheel would be needed. one website shows theres very little difference between the two.i guess im learning the hard way. I do have the k motor that came in it I could build. anyways thank for the help.
Old 09-05-2017, 11:29 AM
Mag engine blocks don't have mounting or provision for points.
Old 09-05-2017, 12:16 PM
would the crank trigger ignitions allow for adjustable timing?
Old 09-05-2017, 12:26 PM
When I was younger and race Jr dragster they sold off-set keys for the flywheel so you could adjust the timing.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-05-2017, 01:10 PM
The ones that mount to the front, yes.
Yeah.... but when you make a change to the engine or want to try different settings, you have to pull the motor, tins and flywheel to change it. Points are soooo easy.
