Old 09-05-2017, 12:10 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default What is needed???
I've been told by multiple sources that I can take the rear lift off my 100 and put it on my 125. I don't ever plan to take the Woods mower off the 100 to work another implement. I am going to drop the Sweepster and use the 125 for other chores however. So any tips on this swap would be grand.. Thanks guys..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 09-05-2017, 12:47 AM
It's pretty simple. Unbolt the lift from the 100, then bolt it onto the 125. Nothing special is needed going from a 0 series to a 4/5 series. They are both narrow frame tractors.
Old 09-05-2017, 02:29 AM
EarlJ's Avatar
Ok just verifying my thinking
Old 09-05-2017, 08:06 AM
How long have you been playing with Cubs?
Old 09-05-2017, 10:44 AM
mortten mortten is offline
If it was a 1X6 1X7 you would need an extra bracket.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 09-05-2017, 01:56 PM
EarlJ's Avatar
About 5 or 6 years I reckon. This is my first 100 and my 3rd 125. The last 2 had hitches on them.
Old 09-05-2017, 08:17 PM
Keep the lift handle bracket attached to the lift arm and slide it in from the back for the 125. Makes life much easier
Old 09-05-2017, 11:09 PM
EarlJ's Avatar
Oh I know that trick very well. I've done installs on many nf tractors. Just wasn't 100% positive if the 100 lift would fit without additional parts.
