Old 09-13-2017, 06:17 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Wheel weights
Anyone know what the L stands for on my weights? Also what is the difference between factory yellow and factory white weights? I weighted them and they both weigh 25.7 pounds, took accurate measurements and they are exactly the same. I see now difference in any of them.
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 09-13-2017, 08:42 AM
What "L"??
The one painted yellow, is yellow. The one painted white is white. That's the difference.
That's because there is no difference between them. They are the same. Boy, you really took a lot of time for nothing......
Old 09-13-2017, 09:00 AM
Probably means left side, where you need them for plowing!!
Old 09-13-2017, 09:52 AM
Dirty Steve's Avatar
There must have been different castings. Here is a shot of a pair I picked up this year. The L is on opposite sides of the IH imprint. Was interesting to see the differences. I have no clue what the "L" stands for.
Old 09-13-2017, 09:59 AM
Maybe L is lew deal.
Really I think it means Louisville plant.
Up to 534 and counting...
Old 09-13-2017, 10:09 AM
Would the white ones be for a Cub and/or Lo-Boy and the yellow for a Cub Cadet?
Old 09-13-2017, 10:28 AM
That is what I'm thinking. Cast in Louisville.
Old 09-13-2017, 11:46 AM
Agreed. Some were cast in the Rowe Foundry in Martinsville, Illinois. (About 25 miles from me. )
Old 09-13-2017, 12:05 PM
So these would have a "R" cast in them big John?
Old 09-13-2017, 12:21 PM
john hall's Avatar
The "L" sounds logical that it identified the foundry, or that it was a mold with multiple pcs produced in the same mold, so it identifies which cavity in case there were bad parts---quality control would then know where to look for the problem. Injection molding does that quite often.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
