Old 09-18-2017, 04:35 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Question Threaded Insert
I was working on/with my 1772 over the weekend and I noticed the threaded insert on the frame where you bolt the snowblower on seems to have fallen out. I was pouring over all the docs and parts manuals I could find, but there is no mention of it. I did find the camlock button mentioned but not this one. Any ideas on how to find the part number?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 09-18-2017, 09:14 PM
If you have the other side intact measure and replace as necessary.
Old 09-19-2017, 11:53 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
It is a 1/2-13 nut with a necked down shoulder on it.You could weld a nut in there but would have to take the motor out.It happened to me on a 982 I just put a serrated flange nut inside and put the bolt in. It is spot welded from the factory.
Old 09-20-2017, 10:23 AM
FrankF3's Avatar
Thanks Mike!
