Old 09-21-2017, 10:16 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default 1782 issues
Found a small leak on my injection pump. Anyone know where I can find the correct seal or know a way to fix it? In the pic its leaking in between the plate with the security torx screws and the pump.
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 09-21-2017, 10:48 PM
There is no seal or gasket there. Only steel shims. That's how you adjust the timing on a Kubota. Make sure the screws are torqued to spec. If a leak is bad and continues, you can remove and clean the shims. DO NOT put silicone on them. That will change the thickness and change the timing.
Old 09-21-2017, 10:54 PM
EarlJ's Avatar
Thanks for the info. I was hoping you'd chime in...I'll try that once I get it back together...
