Old 09-23-2017, 05:09 AM
CubCadet86 CubCadet86 is offline
Default 125 motor in a 86?
I have to get the 8hp motor in my 86 rebuilt. I have a guy with a 12hp out of a 125 for sale locally. Will the 12hp out of the narrow frame fit in my wide frame? Is it a direct swap? I just want to use the tractor till mine gets rebuilt then putting the original motor back in.
Thanks for any help
John
Old 09-23-2017, 06:12 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The 125 engine will fit with some modification. First, the coil will need to be relocated a little higher location to accommodate the the 86 frame. Secondly, you will need to remove the drive hub from the 125 flywheel and install the thee pin driver from your 86 engine for the clutch. Finally, you must remove one of the fuel tanks. The 125 engine has the fuel tank mounted to the engine, whereas the 86 is mounted to the tower assembly. If you are just using the 125 engine temporarily, I would remove the 86 tank for the time being. Personally, I would just rebuild the 8hp engine and be done with it. If you want more hp then look for the correct 10,12,14 or even 16 engine for that series of tractor.
Queen Of The Quietlines!
Old 09-23-2017, 10:28 AM
The 86 is a rare model tractor and nobody here will recommend butchering it by putting in a 12hp. If it's just temporary until you get the engine rebuilt that's one thing but if it's going to be permanent then I recommend selling the 86 to someone who will keep it original and buying a higher hp model.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-24-2017, 12:37 AM
I'm with you guy's. Just going to have the 8hp rebuilt and going back in.
I know the 86 is a little more rare but what makes it the most rare is it was my grandfather's tractor, then my dad's now mine and my sons next. It was bought new.
Sometimes you get horsepower fever. But the 8hp is what makes it special.
Thanks
John
Old 09-25-2017, 02:05 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I wish my 86 looked that good!
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
