Old 09-26-2017, 06:34 PM
Cambria cub Cambria cub is offline
Default 128 Air breather
Moved the the tractor to blow some leafs and notice oil squirting out of the air breather cover!
Old 09-26-2017, 06:38 PM
The breather has a drain hole that could be plugged. I would disassemble the breather and clean it good, make sure to buy new gaskets for it or it will leak.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-26-2017, 06:55 PM
OK will do. is there a whole rebuild kit for it. Thanks frank
Old 09-27-2017, 01:57 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
You can go here to look up the parts #s.
Cub Cadet 128 Engine parts - partstree.com
Parts # 32, 36 in the diagram are the two gaskets. Possibly 40 and 41 if they are degraded or missing. The filter (41) breaks down over time or gets full of dirt. The seal (part 41) is a neoprene sleeve that fits over the stud and holds the reed in place. That is sometimes compressed/deformed, if the cover is put on too tightly. Make sure you assemble with part 38 positioned so the very small drain hole is on the bottom, which allows the oil collected by the filter, to drain back into the engine. Sometimes that drain is plugged. Before assembling, make sure the cover and plate surfaces are flat, to ensure you get a good seal. Make sure the breather reed is positioned over the holes so that they close properly. Sometimes the cover(part # 35) is caved in by previous owners over tightening the nut, trying to seal it. You may need to straighten that out.
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 09-27-2017, 04:31 PM
Or this guy is selling them.
http://www.onlycubcadets.net/forum/s...953#post433953
Old 09-27-2017, 05:56 PM
Even better, everything needed from a forum member. Wish I had seen that a few weeks ago. Just ordered a set from the dealer, for more money.
Old 09-27-2017, 06:07 PM
Thanks. got everything ordered but that neoprene sleeve might have to check into that.is there something you could make that out of.
Old 09-27-2017, 07:28 PM
One of the tractor pulling websites says that "A 1/2" length of 1/4" i.d. soft heat-resistant rubber vacuum hose or reinforced rubber fuel hose will serve the same purpose.", but I have not tried it, so I have no way to confirm it. Up to you if that is the way you want to go.
Old 09-27-2017, 07:32 PM
OK ordered the neoprene sleeve good to go and again thanks Frank
