Old 10-19-2017, 05:36 PM
alsparl alsparl is offline
Default U-Joint Drive Shaft Questions
For those who have performed the conversion from the standard drive shaft connections to one with at least one u-joint as Dave Kemp outlined, how do you like it? Any concerns? Wishes I would have done different? Positives about it?
Did you use the 6N series as he points out or has anyone used the smaller 4P series?
I am asking as I am working with a relative who has a unit of a different color where all the drive line parts are NLA so having to do some fabrication, but using Cub items for the majority of it. He named it "Cub For-det"
Thank you for your time, feedback, and opinions.
Aaron
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 10-28-2017, 08:48 PM
V30crewcab V30crewcab is offline
No idea, but the jd 318's run ujoints on both ends and don't really have problems.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
