Old 06-17-2010, 09:38 PM
denrocks1 denrocks1 is offline
Default What gear do you mow in?
I personally mow in first gear, but I was wondering if any of you guys run in second?
(Using a Cub Cadet 100/102/... anything with the standard three speed)
Old 06-17-2010, 09:43 PM
jbollis's Avatar
jbollis jbollis is offline
I mow in 2nd with the 1806 and 44 inch deck.
Sold everything but one.
Old 06-17-2010, 10:00 PM
1st or 2nd, depending on the conditions.
Actually....I mow with a hydro...
Old 06-17-2010, 10:42 PM
lonnyb's Avatar
lonnyb lonnyb is offline
That all depends on which tractor I am useing.
582-Special = 3rd gear
100 = 2nd gear
Old 06-18-2010, 06:40 AM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
My 1200 has gear drive(with the lower gear set in the transmission) and I mow in second gear. I like the whine from the trans as it sounds like an M22 rock crusher tranny. I have been asked by several pullers to swap them the rear since these are the ones they like.
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 06-18-2010, 04:02 PM
jeffscub's Avatar
jeffscub jeffscub is offline
i'm with you bignasty!! 2nd gear with my 1200 44" deck. jeff
Old 06-18-2010, 04:33 PM
Amigatec's Avatar
Amigatec Amigatec is offline
I just pull the hydro lever down until I am fast enough.
Pat Benner Haskell OK
Old 06-18-2010, 06:21 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
on the deere/farm tractor 5th gear = 4.9 mph, that coupled with the 72 inch deck makes quick work of the main area then i mop up the tight areas with the cc125 and on that i have a 48 inch deck, also have a 44 inch sweeper i just picked up to aid in fall clean up.
could get away with out using the cub but i never plan on getting rid of it, is a solid built tractor made when quality counted, and is a good back up incase of a break down, other people have classic cars i have a classic lawn tractor
Old 06-18-2010, 06:26 PM
IanC's Avatar
IanC IanC is offline
2nd gear on my 100 until I get over my septic, then I have to use 1st.
Ian
CC 125
1980 Scout II
1973 IH Travelette 1210(3/4ton)
Old 06-18-2010, 10:09 PM
JimmyDee5's Avatar
JimmyDee5 JimmyDee5 is offline
Red face Mowing Gear
2nd Gear w/ my 1000 / 44A deck
